in and out ACL on VLAN interfaces
Jan 16th, 2008
could you, please explain me direction when ACL is applied on VLAN interface?
For example, ACL applied like "out" on "interface VLAN 8" means that destination address is in VLAN 8 ?
peter
massimiliano.se... Wed, 01/16/2008 - 06:00
  • Silver, 250 points or more
It means that ACL is applicated to packet directed out that interface. It applies to packet with destination addressess not in VLAN 8.
I hope this helps.
Best regards.
Massimiliano.
acomiskey Wed, 01/16/2008 - 06:17
  • Green, 3000 points or more
Actually that's not correct, if you had the following...
interface vlan 8
ip access-group 100 out
...this means that the destination would be addresses in vlan 8.
If you had...
interface vlan 8
ip access-group 100 in
...then addresses in vlan 8 would be sources.
