acl needed for high security to low security??
Jan 16th, 2008
ive experienced this with both asa and pix...does anybody know why acl needed for high security to low security??...even though i have no high security to low security for other connections?
cisco24x7 Wed, 01/16/2008 - 10:45
you have it backward. By default, hosts behind
high security interface can access hosts behind
low level security interface. You do NOT need
ACL to protect hosts sitting behind high level
security interface from low level security level interface. That is implicitly implied.
You need ACL on the high level security
interface in order to protect/prevent
hosts from getting to hosts on other interfaces. That way, if hosts on the
high level security interface are infected
with viruses, they won't propragate to other
networks on other interfaces.
CCIE Security
szajihsaniatan Wed, 01/16/2008 - 10:49
yeah, i know i dont need a ACL to protect hosts sitting behind high level security interface from low level security level interface....but, in my case, that is not an issue...a higher security lvl was unable to iniate a sqlnet connection to a lower security level with an acl...
Collin Clark Wed, 01/16/2008 - 10:53
Does nothing between the subnets work? Is NAT working or are you routing?
srue Wed, 01/16/2008 - 11:03
do you have inspection turned on for sqlnet?
