Cisco ASA5520 VPN tunnel
Jan 16th, 2008
Can I get an example config of Firewall settings to push to windows clients. Ever since I split the tunnel to only tunnel my network traffic the Windows GPO does not seem to get applied automatically. If I do away with the split tunnel the GPO applies? So I figured I would just push the firewall settings from the ASA but do not any configuration examples. Thanks. And if you have any ideas of why the GPO does not apply it would be helpful.
