Could not login after upgrade from LMS 2.6 to 3.0
Jan 16th, 2008
I have upgraded from LMS 2.6 to 3.0 (Windows 2003 Server). Now I cannot login with my admin and/or user credentials.
Everytime the message "Authentication failed. Please try again." appears.
I have tried the installation two times.
At first as "Typical" installation. At second as "Custom" installation with setting new passwords for admin and guest. But without success.
I would appreciate any hint.
regards Thomas
Overall Rating: 5 (1 ratings)
tschier Wed, 01/16/2008 - 12:13
Yes, I've tried. Unfortunately it doesn't solve my problem.
Joe Clarke Wed, 01/16/2008 - 12:36
Try running the following command:
NMSROOT\bin\perl NMSROOT\bin\
Where NMSROOT is the path in which CiscoWorks is installed. Then restart dmgtd, and see if you can login.
tschier Thu, 01/17/2008 - 00:03
After running with
following output
Changing mode from ACS to CMF ...
Already in CMF mode
my login works again.
Thanx for that hint.
