Loop in network?
Jan 16th, 2008
Our network has crashed a few times within the last two days. Come to find out we have a amber.com switch uplinked via copper to it from cisco equipment.
The amber switch had a cable plugged from one port to another port on the switch.
Would this cause the network to go nutz?
glen.grant Wed, 01/16/2008 - 07:55
  • Purple, 4500 points or more
It certainly could if spanning tree did not handle it correctly if for some reason you have spanning tree turned off . You would have to look to see if one of those ports is either shutdown or blocked for spanning tree . You could do a show spanning-tree blockedports" and see if it is blocked.
