Pix 501 VPN issues
Hi all !
I'm having a couple of issues logging on to my office's network thru VPN. I had it working in a test environment, but when i went live, i haven't been able to logon. I've attached my config file for any suggestions that might help. This is my first experience with Cisco Products.
Some of the main things i changed in the configuration was:
1) changed the domain name to match the existing name of the actually domain (was msti.com, now mstechnology.com)
2) opened ports for access to the server (small business server 2003)
3) changed the ip address of the firewall.
thanks for your help as always !!
acomiskey Wed, 01/16/2008 - 08:02
Since you changed the ip of the firewall, trying re-entering "isakmp enable outside". You may also want to add "isakmp nat-traversal".
