DHCP to allocate same IP to client everytime
Answered Question
Jan 16th, 2008
I would like laptops to get the same IP address from the DHCP pool every time they join the network. Is there a way of binding the laptop MAC address to an IP address so the same IP address is given to the laptop every time?
Correct Answer by ankbhasi about 9 years 3 months ago
Hi Jaime,
Have a look at this link and I believe should help you achieving what you want
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rddhcp.html#wp1017558
Ankur
Overall Rating: 4.5 (2 ratings)
ankbhasi Wed, 01/16/2008 - 09:27
  • Cisco Employee,
Hi Jaime,
Yes that is very well possible on cisco routers/switches working as DHCP server. Can you confirm is you have cisco switches/routers working as DHCP server or some external server?
Ankur
jaimewalker Wed, 01/16/2008 - 09:40
I have a 3750 switch working as a DHCP server.
Thanks for the quick responce,
Jaime
ajagadee Wed, 01/16/2008 - 09:31
  • Cisco Employee,
If you want to configure manual bindings, create a host pool for the 10.10.135.111 address. For example:
ip dhcp pool STATIC
host 10.10.135.111 255.255.255.0
Client-identifier (aabb.ccdd.eeff ...)
default-router 10.10.135.1
domain-name domain.com
option 150 ip 172.16.1.11
dns-server 172.16.1.40 172.17.1.250
netbios-name-server 172.16.1.40 172.17.1.250
ip dhcp pool Data
network 10.10.135.0 255.255.255.0
Below is the URL that has some additional details.
http://www.cisco.com/en/US/docs/ios/12_1/iproute/configuration/guide/1cdipadr.html
I hope it helps.
Arul
shrikar.dange Thu, 01/17/2008 - 01:13
  • Bronze, 100 points or more
hi
An address binding is a mapping between the IP address and MAC address of a client. The IP address of a client can be assigned manually by an administrator or assigned automatically from a pool by a DHCP server.
Manual bindings are IP addresses that have been manually mapped to the MAC addresses of hosts that are found in the DHCP database. Manual bindings are stored in NVRAM on the DHCP server. Manual bindings are just special address pools. There is no limit on the number of manual bindings, but you can only configure one manual binding per host pool.
reffer following link for IOS 12.2 mailline:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75c.html#wp1001108
regards,
shri :)
