AAA w/RSA: "no appropriate authorization type..."
Answered Question
Jan 16th, 2008
  • Bronze, 100 points or more
I have set up a router and a switch for AAA using an RSA RADIUS server. Both are RSA "Agent Hosts" with identical setups. Router (2621XM/EntServ Version 12.4(18)) and switch (3560-24PS/IPBase-12.2(25)SEB2) have identical AAA configs, and RADIUS/RSA is fine as far as the PASSCODE being accepted. But the switch doesn't let me in:
Username: <xxxx>
Password:
PASSCODE Accepted
% Authorization failed.
When I do "deb radius authentication" on each, the outputs are the same up to the last 2 lines. The router that works says:
000055: .Jan 16 12:22:51 EST: RADIUS(00000005): Received from id 1645/3
000056: .Jan 16 12:22:51 EST: RADIUS/DECODE: Reply-Message fragments, 19, total 19 bytes
But the switch says:
000284: Jan 16 12:20:47 EST: RADIUS: saved authorization data for user 3030220 at 3034440
000285: Jan 16 12:20:47 EST: RADIUS: no appropriate authorization type for user.
The only other difference I can think of is that I use ssh to the router and telent for the switch (IPBase apparently no habla "crypto", I could use a different IOS I think.
Any clue? TIA
Paul
Correct Answer by cisco24x7 about 9 years 2 months ago
If I were you, I would "disable" authorization
on the catalyst 3560. I haven an identical
setup like yours on mine Catalyst 2960 and it
works just fine. See below:
[[email protected] root]# telnet 192.168.0.5
Trying 192.168.0.5...
Connected to 192.168.0.5 (192.168.0.5).
Escape character is '^]'.
C
User Access Verification
Username: test4
Password:
Enter your new PIN, containing 4 to 8 digits,
or
to cancel the New PIN procedure:
Please re-enter new PIN:
Wait for the code on your card to change, then log in with the new PIN
Enter PASSCODE:
C2960#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(25)SEE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 16-Jul-07 02:53 by myl
Image text-base: 0x00003000, data-base: 0x00CC0000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
C2960 uptime is 2 weeks, 6 days, 14 hours, 10 minutes
System restarted at 23:20:30 GMT Wed Dec 26 2007
System image file is "flash:c2960-lanbasek9-mz.122-25.SEE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
Processor board ID FOC1036X0F1
Last reset from power-on
2 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:55:1B:D6:00
Motherboard assembly number : 73-10015-05
Power supply part number : 341-0098-02
Motherboard serial number : FOC10352NF2
Power supply serial number : AZS103402ZF
Model revision number : B0
Motherboard revision number : B0
Model number : WS-C2960G-24TC-L
System serial number : FOC1036X0F1
Top Assembly Part Number : 800-26673-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COM3G00BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960G-24TC-L 12.2(25)SEE4 C2960-LANBASEK9-M
Configuration register is 0xF
C2960#sh run | inc aaa
aaa new-model
aaa authentication login test group radius local
aaa authentication login test1 group tacacs+ local
aaa authentication login notac local
aaa authentication dot1x default group radius
aaa session-id common
C2960#
CCIE Security
Overall Rating: 5 (1 ratings)
Correct Answer
cisco24x7 Wed, 01/16/2008 - 10:34
  • Silver, 250 points or more
C
Username: test4
Password:
or
Enter PASSCODE:
C2960#sh ver
[email protected].
Version ID : V02
aaa new-model
C2960#
CCIE Security
PAUL TRIVINO Wed, 01/16/2008 - 11:29
Outstanding - thanks! That did it. Interesting that the switch (maybe IPBase image?) is so significantly different. OTOH maybe I don't need it on the router either, I got the suggestion from another NetPro user to use:
line vty 0 4
privilege level 15
to get to Enabled mode, which works fine too.
Much grass!
Paul
