Creating a dot1q trunk on a 7200
Jan 16th, 2008
okay...I must be loosing my mind. I'm trying to configure a fastethernet interface on a 7200 to be a 802.1q trunk to a Cisco 4000 switch.
I created the subinterface:
fastethernet 0/0.1
but in the subinterface config there's no encapsulation command.
What am I missing here?
Jon Marshall Wed, 01/16/2008 - 09:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Frank
The 7200 does support 802.1q so it is probably the feature set that you are missing. You need a minimum of IP Plus to support 802.1q encapsulation.
Jon
ankbhasi Wed, 01/16/2008 - 09:52
  • Cisco Employee,
Hi Frank,
I hope you are not running IP BASE feature set image. You need minimum IP PLUS to support encapsulation command.
Ankur
ajagadee Wed, 01/16/2008 - 09:54
  • Cisco Employee,
This could be an issue with the code that you are running on the 7200. If I remember correctly, you need a minimum of IP Plus feature set to do 802.1q encapsulation.
Arul
