AAA Authentication issue with menu
Jan 16th, 2008
I have a menu system set up on a terminal server (3660 Router) and everything seems to be ok except one little annoyance. We use AAA to authenticate and authorize the connections in to our router (for admin and for menu use). Once a user gets to the menu option and selects it they get prompted to enter AAA credentials for telnet (since we use reverse-telnet) and then they will get prompted after that for credentials in the the box they are trying to reverse-telnet in to. Any idea why this happens and how to fix it? I would like for the user to not have to authenticate twice for the reverse telnet connections. Any help would be appreciated. I will post config if you guys need it.
