VPN 501 to VPN 515
Jan 16th, 2008
I am having an issue with one of my remote sites. We are creating a VPN tunnel from a PIX 501 (remote site) to PIX 515 (corporate office). Initally, the vpn tunnel is created and the users can access resource on our corporate network (i.e. email, files, printers, etc.) but after closing outlook or letting the system sit awhile, I lose the vpn tunnel and the only other way to re-establish the connection is to power cycle the PIX 501.
Any advice would be greatly appreciated
DK
htarra Tue, 01/22/2008 - 12:32
  • Bronze, 100 points or more
I understand that you would like to setup PIX-to-PIX connection. For your reference please do have a quick look in this link:
Configuring a Simple PIX-to-PIX VPN Tunnel Using IPSec
http://www.cisco.com/warp/public/110/38.html
I looked through Cisco IOS documents, and the only way I found for IOS was
through using another tunnel (e.g. GRE:
http://www.cisco.com/univercd/cc/td/doc/solution/v3pnipmc.pdf), which is
not supported on ASA/PIX.
ajagadee Tue, 01/22/2008 - 13:08
  • Cisco Employee,
How does the Pix 501 connect to the Pix 515. Is the Pix 515 configured as EzVPN Server or is the Pix 515 configured to accept Dynamic IPSec Connections.
If the Pix 515 is configured for EzVPN Server, I would definitely look at Network Extension Mode(NEM) on the pix 515 to keep the tunnel up all the time. Please refer the below URL for details:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008019e6d7.shtml
Arul
** Please rate if it helps **
