Cisco Fax Server autoreply configuration
Answered Question
Jan 16th, 2008
I'm running RightFax version 9.3
I want to configure autoreply
these are the steps that I'm following
To configure the AutoReply service
1. On the RightFax server, open a view of the RightFax\AutoReply
folder and run ARWizard.exe. This starts the AutoReply wizard.
2. In the Add/Remove RightFax Server window, click Set up
and configure a new RightFax server. Click Next.
however THE ARWizard.exe is not in the AutoReply folder
any help would be greately appreciated
Correct Answer by smahbub about 9 years 1 month ago
The RightFax Docs-on-Demand" feature is a fax server-based document retrieval system that has two components:
Fax-on-Demand and Web Fax Tools. Fax-on-Demand allows anyone to call your server and request library documents via a touch-tone telephone. Web Fax Tools lets people request library documents from a Web site. Only library documents that have been made specifically available to Fax-on-Demand or the Web may be retrieved. For more information on creating and configuring library documents, refer to the RightFax Administrators Guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/fax_server/93/93ciscofaxdocsondemand.pdf
Overall Rating: 5 (1 ratings)
Correct Answer
smahbub Tue, 01/22/2008 - 12:34
