Enable Transparent Tunneling on VPN client?
Answered Question
Jan 16th, 2008
Hi, I can connect to my Cisco Concentrator using my Cisco VPN Client if I turn off the transparent tunnel option or turn it on using either IPsec over UDP or IPsec over TCP, does either of these 3 options provide better security or speed, or am I OK just to use the default for my users which is transparent enabled and IPsec over UDP?
Correct Answer by acomiskey about 9 years 5 months ago
IPsec over udp is fine. If you were to disable it you would likely find people having trouble establishing communications behind nat devices. I don't believe one is more secure than the other, but I do think over udp is faster than over tcp.
Overall Rating: 4.5 (2 ratings)
Correct Answer
acomiskey Wed, 01/16/2008 - 12:17
  • Green, 3000 points or more
