Network address translation configuration issue
Jan 16th, 2008
IP want to apply Network address translation on my cisco router
i have 4 e1's and two ethernet interfaces, i want to utilize only one ethernet right now
I have 4 Public IPs on 4 E1s (virtual serial interface)in s a way
now i want to perform NAT in such a way that my (single)router's one ethernet port can translate
equally to 4 e1's in other words one private ip into 4 public addresses.
for one E1 i have done following configurations
#acces-list 1 permit x.x.x.x(prive 172) 0.0.255.255
#ip nat inside source list 1 int s0/0 overload
conf)#int giga 0/1
conf-if)#ip nat inside
conf)#int s0/0
conf-if)#ip nat outside
first please check, is above configuration is right for single translation?
now i want to apply this on 4 e1 (s0/0,s0/1/,s1/0,s1/1) please tell me configuration for his
write here
thanks
Collin Clark Wed, 01/16/2008 - 12:50
  • Purple, 4500 points or more
You do not need to apply "ip nat outside" on each individual serial interface. You can just apply once to your virtual interface. Also with "ip nat inside source list 1 int s0/0 overload" you should specify your virtual interface instead of s0/0.
HTH and please rate.
m_aurangzeb Wed, 01/16/2008 - 20:38
I have done this on virtual interface as below but not working can u write commands here
aaccording to given below configuration, i am unable to ping from my Computer.
please tell me what is the purpose of overload command if i dont write it , then will it make any difference
interface GigabitEthernet0/1
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
ip address x.x.0.1 255.255.0.0 (private IP pool)
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
access-list 1 permit X.X.X.X. X.X.X.X (private IP pool
p nat inside source list 1 interface Serial0/0/0:0 overload
bandwidth 2048
ip address x.x.x.x x.x.x.x (WAN IP)
ip nat outside
mohammedmahmoud Thu, 01/17/2008 - 00:16
  • Green, 3000 points or more
What about the routing part, are you using static routes (most commonly a default route) to point out to the serial interface. Before the NATing can be done, the router must route the packets to the outgoing interface.
BR,
Mohammed Mahmoud.
Collin Clark Thu, 01/17/2008 - 06:17
Please post a sanitized config.
