having issues with asa and ezvpn
Jan 16th, 2008
Im having issues getting ezvpn to work with my asa 5520. I can get L2L ipsec connections working and my vpn clients work but when I try an ezvpn connection the tunnel will come up for a second and then will disconnect. I am using a 3g wic for my connnection.
Im running ios 12.4(11)XV1.
Here are some logs from the asa:
713905 Group = fcb, IP = 99.203.249.159, No valid authentication type found for the tunnel group
113009 AAA retrieved default group policy (FBC-VPN) for user = fcb
713131 Group = fcb, IP = 99.203.249.159, Received unknown transaction mode attribute: 28692
713131 Group = fcb, IP = 99.203.249.159, Received unknown transaction mode attribute: 28693
713184 Group = fcb, IP = 99.203.249.159, Client Type: IOS Client Application Version: 12.4(11)XV1
713131 Group = fcb, IP = 99.203.249.159, Received unknown transaction mode attribute: 28695
713228 Group = fcb, IP = 99.203.249.159, Assigned private IP address 172.25.1.1 to remote user
713201 Group = fcb, IP = 99.203.249.159, Duplicate Phase 2 packet detected. Retransmitting last packet.
713902 Group = fcb, IP = 99.203.249.159, Removing peer from peer table failed, no match!
713903 Group = fcb, IP = 99.203.249.159, Error: Unable to remove PeerTblEntry
713904 IP = 99.203.249.159, Received encrypted packet with no matching SA, dropping
joreilly36678@y... Tue, 01/22/2008 - 11:58
Do you see the message "Cannot obtain an IP address for remote peer" following the message you have mentioned. In that you need to create an address pool and assign addresses to this pool.
jefferyprice@te... Wed, 01/23/2008 - 13:11
the router is getting a client address.
