5K new APs and nothing to manage them with..suggestions ?
unfirenothomas Wed, 01/16/2008 - 18:45
I would look into using Airwave: www.airwave.com
Note that Aruba has just bought out AirWave but they still support multiple vendors. Works well for commercial APs but probably not Linksys. Could consider something like ActiveXperts to monitor up/down of the alternate APs.
bcolvin Wed, 01/16/2008 - 21:46
  • Bronze, 100 points or more
Andy
If Linksys has a mib file for the AP the Solarwinds SNMP manager should give you some management caoabilities. this would apply any other SNMP manager you chose. You may have uncovered one of the major differences between the WIFI products destined for the lower end of the price range and the ones classified as Enterpise AP's
Good Luck
Bill
There is a product from AirWave ( www.airwave.com ) that manages access points from multiple manufacturers (including Cisco). The product can scale up to 10,000+ access points. You might want to contact them to find out what their support is for Linksys.
Hope this helps,
- John
Please rate helpful posts!
Trending Topics - Security & Network
