can't set the parameter AdminPowerMax higher that 7000 mW.
Jan 16th, 2008
Look at systemdump:
SGDFPSAcc2#sh power inline fastEthernet 4/13
Available:1400(w) Used:315(w) Remaining:1085(w)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Fa4/13 static off 7.0 7.0 n/a n/a
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Fa4/13 7.0 7.0
SGDFPSAcc2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
SGDFPSAcc2(config)#fast
SGDFPSAcc2(config)#in
SGDFPSAcc2(config)#interface fas
SGDFPSAcc2(config)#interface fastEthernet 4/13
SGDFPSAcc2(config-if)#pow
SGDFPSAcc2(config-if)#power in
SGDFPSAcc2(config-if)#power inline ?
auto Automatically detect and power inline devices
consumption Configure the inline device consumption
never Never apply inline power
static High priority inline power interface
SGDFPSAcc2(config-if)#power inline au
SGDFPSAcc2(config-if)#power inline auto m
SGDFPSAcc2(config-if)#power inline auto max ?
<4000-7000> milli-watts
The parameter :
SGDFPSAcc2#sh power inline consumption default
Default PD consumption : 15400 mW
aghaznavi Tue, 01/22/2008 - 12:54
If you set a small value for the power allocation, all connected inline power devices initially are powered up, but after you receive the CDP messages, the system learns that devices consume more power and deny power to some of the ports. If you set a small value, it can also result in the overdraw of power for some time with unanticipated results, such as hardware failures and unexpected resets. 7000 milliwatts (mW) is the maximum power supported for these modules.
