Changing Security level through the MC
Jan 16th, 2008
Is there a way to turn the security level to off through the MC. I believe if you are an admin this should be an option.
tsteger1 Fri, 01/18/2008 - 14:23
Hi Bruce,
You can do this with a set rule and a triggering event from the MC.
I don't think there is a way to set the security level like there is to reset it from the MC.
