Console connection freezes up
Jan 16th, 2008
Hey guys,
when I access a router or a switch (I dont' remember if it does it in firewalls as well) via the light-blue console cable, I have to restart the device.
I use Hyper Terminal from windows and I get this problem a lot because if I want to access the router via the console few days later, I can no longer get in. Access thru telnet/ssh is always good.
Is there any settings on the console line that prevents or perhaps freezes the console line after a certain amount of time?
Once again, I have to restart the router or the switch in order to see and access the prompt.
JORGE RODRIGUEZ Wed, 01/16/2008 - 21:01
  • Green, 3000 points or more
Most likely is your terminal emulator,
does your terminal have these settings
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
If term setting are correct have you tried console using a different system other than the one you normaly use, have you tried a different concole cable.
It would be odd that this is a problem in multiple cisco devices, router, firewall, switch..
Rgds
Jorge
insccisco Thu, 01/17/2008 - 06:46
yes, all my terminal emulator settings are correct.
I do agree these problems are strange. I connect fine, do my things, then I lock the PC (I do leave the hyper termninal session open mpst of the time though)
and then 2 or 3 days later, I try to go back to the hyper terminal window but it does not let me type anything. So I close the HT session, open up a new one, but same thing... I can't type anything nor see anything from the router (not even a prompt)
Again, the only fix is rebooting the device and once I do, I then see activity via the HT window and I can also type stuff
