PIX506e vpn works, but not web page, behind single ip dsl
Jan 16th, 2008
Tried to configure a web page on ip, I think it has something to do with having a single static ip and nat not configured correctly, any help would be appreciated.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname pixfirewall
domain-name ciscopix.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list inside_outbound_nat0_acl permit ip host
access-list outside_cryptomap_dyn_20 permit ip any
access-list outside_access_in permit tcp any host 96.230.999.999 eq www
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 96.x.x.138
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool mfcd
pdm location inside
pdm location outside
pdm location inside
pdm location inside
pdm location inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0 0
static (inside,outside) tcp 96.230.999.999 www www netmask 0 0
access-group outside_access_in in interface outside
route outside 96.230.999.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server TACACS+ (inside) host timeout 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map inside_map client authentication LOCAL
crypto map inside_map interface inside
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address inside
dhcpd dns 71.x.x.12
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain myhome.westell.com
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
ajagadee Wed, 01/16/2008 - 18:40
What is the IP Address that the is getting NATTed to. Is it by any chance the outside interface of the Pix.
In case if you are using the outside interface and doing port redirection, then you have to use the interface keyword when configuring Static if you want the traffic to hit the outside IP and get translated.
You must use the interface keyword instead of specifying the actual IP address when you want to include the IP address of a PIX Firewall interface in a static PAT entry
Please refer the below URL for details.
Let me know if it helps.
dgrafmiller Tue, 01/22/2008 - 17:01
I replaced the static with:
static (inside,outide) tcp interface www www netmask 0.0
But still doesn't work?
