Monitoring the Concentrator
Jan 16th, 2008
We have a 3030 VPNC via which there are IPSec siti-to-site tunnels and remote access vpn's for remote users.
I need to have a monitoring tool by which i can check the logs and which can also help me to troublshoot any problems.
Kindly let me know if you have information on the same.
Amol.
Overall Rating: 3 (1 ratings)
Collin Clark Thu, 01/17/2008 - 10:38
  • Purple, 4500 points or more
It supports SYSLOG so you could have it dump its logs there. I've always used the log via the web interface for troubleshooting.
HTH and please rate.
rush2amol Thu, 01/17/2008 - 19:57
Thx,
I do check the same using its web interface but its not elaborate, there is no phase vis distribution of logs and its really not easy to understand.
Amol.
