k.korlyakov Wed, 01/16/2008 - 23:32
"The Frame Relay switching enhancement feature currently does not support SVC switching functionalities. Presently, only PVC switching is supported."
Feature Navigator says the same - FR SVC Switching not yet supported :(
Thanks for help,
Kirill
pcameron Fri, 01/18/2008 - 10:18
  • Cisco Employee,
if you just want to connect two routers back to back without a frame relay network in the between (for example another IOS router configured as a FR switch) there are two ways -
1) disable LMI keepalive on the interface. This stops router from sending or expecting LMI traffic so the interface will stay up permanently.
router 1
interface serial X/Y
encapsulation frame-relay
no keepalive
router 2
no keepalive
2) use the following configuration on one router to configure it as a frame relay DCE so it interfaces directly to the other frame relay DTE device -
frame-relay switching
frame-relay intf-type dce
you would still use PVC's via the same DLCI to pass traffic between each router.
Refer here for full details on frame relay config commands -
http://www.cisco.com/en/US/docs/ios/12_1/wan/command/reference/wrdfrely.html#wp1021315
