show arp result and default value prameter in ACE.
Jan 16th, 2008
I was wondering whether the output of show arp.
the sample arp table like below:
IP ADDRESS MAC-ADDRESS Interface Type Encap NextArp(s) Status
192.168.1.1 00.1c.b0.b5.99.80 vlan10 GATEWAY 2 74 sec up
192.168.1.11 00.1c.f9.fc.fe.40 vlan10 LEARNED 4 13270 sec up
192.168.1.100 00.0a.b8.65.cf.f9 vlan10 VSERVER LOCAL _ up
192.168.1.10 00.13.77.03.45.51 vlan20 RSERVER 6 168 sec up
192.168.1.2 00.0a.b8.65.cf.f9 bvi90 INTERFACE LOCAL _ up
Total arp entries 5
the 192.168.1.100 is vip address configured
the 192.168.1.10 is realserver configured
I deattached the 192.168.1.10,
the result like below
Context Bridge
192.168.1.1 00.1c.b0.b5.99.80 vlan10 GATEWAY 2 47 sec up
192.168.1.11 00.1c.f9.fc.fe.40 vlan10 LEARNED 4 13243 sec up
192.168.1.10 00.00.00.00.00.00 bvi90 RSERVER - * 1 req dn
Total arp entries 5
switch/Bridge# show arp
192.168.1.10 was downed, but 192.168.1.100 is up, Is it working correctly?
I throught that if the real server down, then the 192.168.1.100 was dn status.
any throught or suggestions?
there are many default parameter in ace
for example, the random-sequence-number in tcp paramter.the default on.
Is it working? although I didn't configure parameter policy?
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 01/17/2008 - 00:59
yes this is normal.
the ARP entry for vserver is always UP.
But if you check the status of the vip inside the service policy you should see :
VIP state: OUTOFSERVICE
Regarding the default options, they are applied by default, even without a policy-map configured.
Gilles.
