ISP default gw?
Answered Question
Hi, I have a Cisco 877w and I have it configured with "IRB" like this guide:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a581.shtml
I have one problem with this, and it is that the default route to ISP gw is staticly configured.
ip route 0.0.0.0 0.0.0.0 <default gateway to isp>
Usually this is a parameter that tends to be set automaticly on other routers I have used. See, my ISP uses a pool of gateways depending on what IP I'm assigned. I am assigned an IP using DHCP!! Is there another way than configuring this staticly?
Correct Answer by paolo bevilacqua about 9 years 5 months ago
Depending on the IOS version, you can either remove that command at all, or replace it with ip route 0.0.0.0 0.0.0.0 dhcp.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 01/17/2008 - 01:48
  • Hall of Fame,
    Founding Member
