Snmp
Jan 17th, 2008
Hi All
Will enabling snmp on a Cat2960 acting purely as a L2 switch afftec performance?
We want to remove as much as possible any overhead on the switch so have turned off as much as we can.
cisco24x7 Thu, 01/17/2008 - 04:46
  • Silver, 250 points or more
I don't know if it is possible to do that on
Cat2960 because the command "sdm prefer vlan"
is NOT available in Cat2960, only with
Cat3550:
C2960(config)#sdm prefer ?
default Default bias
qos QoS bias
CCIE Security
qwertys21 Thu, 01/17/2008 - 04:53
Thanks, I was asking about snmp. What is sdm? Thanks
Collin Clark Thu, 01/17/2008 - 07:08
  • Purple, 4500 points or more
Where do you have performance concerns? Running services will increase CPU/memory but should not effect port performance.
