how to start DCA server
Answered Question
Jan 17th, 2008
I have installed LMS 2.6. However the error message DCA server down pops up. How can I start the DCA server. Iam new to ciscowors and could not find the option for the above.
Correct Answer by Joe Clarke about 9 years 5 months ago
I see your problem. Your COMPUTERNAME is now KSWANLMS, but it used to be KSWAN_LMS when LMS was first installed. This is causing your problem. You need to follow the steps at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.0/user/guide/diagnos.html#wp1078582 to teach LMS the new hostname. Additionally, there is one other registry key under HKLM\SOFTWARE\Cisco that will have the old hostname. Change all instances of the old name to the new name.
If after all of this, the hostname is still KSWAN_LMS in sso.properties, modify the hostname there, then restart dmgtd.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 01/17/2008 - 08:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The DCRServer daemon will come up automatically provided there are no issues. If it is not started, that points to a problem with either it, or one of its dependencies. Please post the output of pdshow as well as the NMSROOT/MDC/tomcat/logs/stdout.log.
rajesh1331 Fri, 01/18/2008 - 00:59
Hi clarke..
Thanks for ur response. Iam attaching both the files along. It woulf be very helpful if you can find me a solution
rgds
rajesh
Joe Clarke Fri, 01/18/2008 - 09:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post NMSROOT/lib/classpath/sso.properties.
Joe Clarke Wed, 01/23/2008 - 11:11
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the output of "set" from a DOS command prompt.
Correct Answer
Joe Clarke Wed, 01/23/2008 - 22:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
rajesh1331 Thu, 01/24/2008 - 03:42
Hi clarke..
Thanks a lot for that support. It is working fine now.
Thanks and regards
Rajesh
