Aironet 1250 channel bonding - config 802.11a chan_width
Jan 17th, 2008
Hi ,
I tried to bond two 20MHz channels on a 1250 (802.11A - LWAPP - 12.4(10b)JA) but get the following error:
' Slot is not Disabled or Customize is not enabled'
I have disabled the 802.11network/ radios etcetc but no luck yet.
Reg
Goen
Overall Rating: 5 (2 ratings)
fielderj Wed, 04/09/2008 - 11:35
I am having the same issue while in LWAP mode.
According to this document:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
40mhz is supported on WLC's, it even gives steps on how to enable it, but I am receiving the same error as the original poster.
I was able to successfully deploy 802.11n @ 40mhz in autonomous mode, but the operation fails in LWAP mode.
I am going to open a TAC case to see if this is a bug.
Jeremy
Scott Fella Wed, 04/09/2008 - 14:51
You have to set the channel first then change the channel width. You might have to set the power also...
If you want to set above 40MHz use these channels: 36,44,52,60,100,108,116,132,149.157
If you want to set below 40MHz use these channels: 40,48,56,64,104,112,136,153,161
Hope this helps.
edward_bacon Wed, 11/12/2014 - 09:45
Hi Jeremy, I see your post is very old but I wanted to reply in case Cisco TAC was able to solve your issue and ask if you know of a way to set the Channel Width with Templates or CLI.
Ed
Rasika Nayanajith Wed, 11/12/2014 - 11:37
Hi Ed,
Did you try something like below. Replace your AP name with LAP1 below.
(5508-1) >config 802.11a disable LAP1
(5508-1) >config 802.11a chan_width LAP1 40
(5508-1) >config 802.11a enable LAP1
(5508-1) >save config
Are you sure you want to save? (y/n) y
Rasika
**** Pls rate all useful responses ****
edward_bacon Wed, 11/12/2014 - 12:25
The AP I was testing was on the wrong channel for 40mhz width.
THANKS
Abhishek Abhishek Tue, 11/18/2014 - 18:08
I am sorry to say that you cannot mix the channel 20MHz channels on a 1250 (802.11A - LWAPP - 12.4(10b)JA)
gohussai Mon, 07/06/2015 - 12:59
Yes i tested.
Try this from Controller console.
First disable the 802.11a then mention the below commands for your LAP.
save config
hope this will work.
Note: If problem persist ,reimage the lap and try again.
