Frame Relay traffic shaping
wgranada1
Good day
I'm trying to traffic shape a circuit I have currently it is set up to take the full T1 1536K what I wanted to do is shape that to only take 1M how or can someone point me to a doc that tells me how to do this? Thank you in advance!!!
12 Replies 12
Edison Ortiz
You can do Frame-Relay Traffic Shaping (FRTS) or Generic Traffic Shaping (GTS) with Modular QoS CLI (MQC).
With FRTS, you have the ability to shape per PVC while with GTS, it treats the interface as a single interface. In other words, you can designated traffic to DLCI 101 without affecting DLCI 102.
Due to this limitation, it's often recommended to shape using FRTS vs GTS.
Can you provide your config and network topology ?
__
Edison.
Sure basically I have a point to point connection. Here is the config on both ends:
Far end:
interface Serial0/0/0
bandwidth 1536
ip address 172.19.90.126 255.255.255.252
encapsulation frame-relay
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-24
frame-relay traffic-shaping
frame-relay map ip 172.19.90.125 121 broadcast
frame-relay lmi-type cisco
end
Near end(my end)
interface Serial0/0/0.138 point-to-point
description PVC to sfscitrt2
bandwidth 256000
ip address 172.19.90.125 255.255.255.252
no ip mroute-cache
no cdp enable
frame-relay class cit-fr-cmap
frame-relay interface-dlci 138
end
map-class frame-relay cit-fr-cmap
frame-relay cir 256000
frame-relay bc 32000
frame-relay be 160000
frame-relay mincir 128000
frame-relay adaptive-shaping becn
service-policy output cit-pmap-egress
I didn't see a map class on the far end
My goal is to stop this connection from taking
over the whole Frame T1. Whenever this connection burst up to the Full T1 I lose connectivity to 2 sites
Also to add I have a Frame T1 with 10 other connections on it not sure why we have a connection on a Frame T1 that can burst up to T1 speed but we do everthing else is 128k the second biggest connection is 512k
On this router, you implemented FRTS - which is great !
It's configured for 256kbps and mincir 128kbps, can we see the config from the router you want to change ?
Please, also indicate how much traffic you want allocated per DLCI.
On a public forum I'm not allowed to do so but
if you have a email address I can send it to you. I noticed that FRTS is only configured on my router(near end) but the remote end
I don't see anything configured.
Just mask the ip addresses and DLCI information. I just want to have a general idea of how the config looks like.
You need to configure FRTS on the hub and spokes. You've only posted the config from one of the spokes.
Here it is....
Current configuration : 12669 bytes
! Last configuration change at 14:13:24 UTC Thu Jan 17 2008 by wgranada
! NVRAM config last updated at 20:31:35 UTC Fri Dec 7 2007 by wgranada
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
no service dhcp
hostname sfscitrt2
boot-start-marker
boot system flash flash:c2800nm-advipservicesk9-mz.124-3d.bin
boot-end-marker
security authentication failure rate 10 log
logging buffered 16000 informational
no logging console
aaa new-model
aaa session-id common
resource policy
ip subnet-zero
no ip source-route
ip gratuitous-arps
ip tcp selective-ack
ip tcp path-mtu-discovery
ip cef
track 10 rtr 1 reachability
track 20 rtr 2 reachability
class-map match-all cit-pref-cmap-egress
match access-group 182
policy-map vti-pmap
class class-default
shape average 512000
policy-map cit-pmap-egress
class cit-pref-cmap-egress
bandwidth percent 85
class class-default
fair-queue
crypto logging session
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key
crypto isakmp keepalive 10
crypto ipsec transform-set
crypto ipsec profile vti
set transform-set sfscitrt2-tset
interface Tunnel101
bandwidth 512000
ip address XXXXX
ip nat inside
ip virtual-reassembly
ip ospf network point-to-point
tunnel source this router
tunnel destination distant end ip
service-policy output vti-pmap
interface Null0
no ip unreachables
interface Loopback0
ip address XXXX
ntp disable
interface FastEthernet0/0
ip address XXXX
ip access-group SFSHOSTS in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip rip send version 2
ip rip receive version 2
no ip mroute-cache
duplex full
speed 100
ntp disable
no cdp enable
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
bandwidth 1536
ip address XXXXX
no ip mroute-cache
no fair-queue
frame-relay map ip distant end IP 121 broadcast
interface BRI0/1/0
no ip address
shutdown
router ospf 1
router-id XXXX
log-adjacency-changes
summary-address
summary-address
summary-address
summary-address
redistribute connected subnets route-map redis-connected
redistribute static metric 5 subnets route-map redis-static
redistribute rip metric 5 subnets route-map redist-from-citi
passive-interface default
no passive-interface Tunnel101
network XXXX area 2
router rip
version 2
redistribute static metric 5 route-map announce-to-citi-rmap
no passive-interface FastEthernet0/0
network XXXX
distribute-list announce-to-citi-list out
distribute-list citi-cep-routes in
distance 75
no auto-summary
ip classless
map-class frame-relay 256/128
frame-relay cir 1536000
frame-relay bc 192000
frame-relay mincir 768000
no cdp run
route-map redist-from-citi permit 10
match ip address citi-cep-routes
route-map redis-connected permit 10
match ip address 31
route-map announce-to-citi-rmap permit 10
match ip address announce-to-citi-list
route-map redis-static permit 10
match ip address 32
control-plane
end
I don't see any subinterfaces and I don't see what circuit you want to allocate the bandwidth.
What I need for you is a breakdown on how you want to divide the T1 per DLCI.
Sorry this is the distant end all the subinterfaces are at my end(NEAR End)
The config is a lot longer so it will take a few
You have shaping enabled on this router but you have not applied any policy to it. Was that your intention ?
__
Edison.
Not sure as I didn't configure this router but I think if I enable shaping on both ends and install the correct policy then I think I would be limit this PVC to 1 meg. All I really did was take the existing policy and chaged 1536000 to 1000000:
frame-relay cir 1000000
Right, currently the router is shaping to 56kbps.
You can verify with the command show frame pvc [dlci]
Ok I know what I need to do now thanks for knocking off the cob webs I will give it a shot this weekend and we will see what happens. thank you for your help!!!!!
