Access-list does not exist
Jan 17th, 2008
I am trying to remove the access-list of the PIX , but is appearing that the access-list does not exist.Following in annex the access-list
AGUA/B# show run access-list
access-list intranetB_access_in extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB
AGUA/B# show access-list
access-list cached ACL log flows: total 322, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list intranetB_access_in; 11758 elements
access-list intranetB_access_in line 1 extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB (hitcnt=0) 0xb747ec78
AGUA/B(config)# no access-list intranetB_access_in line 1 extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB
Specified access-list does not exist at that line
Collin Clark Thu, 01/17/2008 - 07:27
You're close, you do not need line 1, so it should be-
no access-list intranetB_access_in extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB
HTH and please rate
rogerio.mitsuo Thu, 01/17/2008 - 07:39
I try(copy/paste with no) in CLI without the line 1 , but the same message appeared to me
AGUA/B(config)# no access-list intranetB_access_in extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB
I tried also by ASDM with option DELETE , but the message is the same "Specified access-list does not exist".
Collin Clark Thu, 01/17/2008 - 07:45
Can you post a sanitized ACL? Command should be show run | inc intranetB_access_in
rogerio.mitsuo Thu, 01/17/2008 - 08:00
Yes.
AGUA/B# show run | inc intranetB_access_in
access-group intranetB_access_in in interface intranetB
Collin Clark Thu, 01/17/2008 - 08:28
I think the name might be the problem. Try this,
firewall#config t
firewall(config)# no names
Then find the entry you want to remove. The names will be gone and IP's will be in their place. Then try removing it. Let us know what happens.
rogerio.mitsuo Thu, 01/17/2008 - 09:03
Following the result :
AGUA/B(config)#no names
AGUA/B(config)#show run | inc intranetB_acess_in
access-list intranetB_access_in extended deny ip host 10.217.9.103 interface intranetB
AGUA/B(config)#no access-list intranetB_access_in extended deny ip host 10.217.9.103 interface intranetB
AGUA/B(config)#
Collin Clark Thu, 01/17/2008 - 09:15
Is there anything in the log? There are other lines in the ACL correct?
rogerio.mitsuo Thu, 01/17/2008 - 10:10
I will see the log tommorow cause the backup is done of one day to other. Yes - correct
rogerio.mitsuo Fri, 01/18/2008 - 08:25
Following the log :
Jan 17 12:31:48 pix525-B %PIX-0-111008: User 'rmitsuo' executed the 'no access-list intranetB_access_in extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB' command.
Jan 17 12:31:48 pix525-B %PIX-0-111008: User 'failover' executed the 'no access-list intranetB_access_in extended deny ip host rgt-infor3.rgt.sabesp.com.br interface intranetB' command.
rogerio.mitsuo Mon, 07/27/2009 - 05:55
Please. I am not getting to install a csm 3.2.0 . The following message is appearing . The directory does not exist. Please choose the correct directory.
