FWSM 3.1(8) - Security context high CPU usage
Jan 17th, 2008
Hi Sir,
Below is output of "sh cpu usage context all" on a FWSM version 3.1(8):
FWSM# sh cpu usage context all
5 sec 1 min 5 min Context Name
10.0% 9.0% 8.9% system
0.0% 0.0% 0.0% admin
47.5% 46.4% 45.8% fwsm-context1
0.0% 0.0% 0.0% fwsm-context2
0.1% 0.0% 0.0% fwsm-context3
1.3% 1.2% 1.2% fwsm-context4
0.4% 0.4% 0.4% fwsm-context5
0.2% 0.1% 0.1% fwsm-context6
0.3% 0.2% 0.2% fwsm-context7
0.1% 0.1% 0.1% fwsm-context8
0.0% 0.0% 0.0% fwsm-context9
0.2% 0.0% 0.0% fwsm-context10
Any way to see the breakdown of the CPU processes that contribute to the high utilization of fwsm-context1?
Users have been complaining slow access to servers connected to fwsm-context1 after the FWSM was upgraded from 2.3(3) to 3.1(8). Unfortunately I don't have the benchmark of the CPU usage on version 2.3.
Thank you.
B.Rgds,
Lim TS
jsivulka Wed, 01/23/2008 - 09:41
In FWSM 3.x, "show cpu context all" shows where ALL the CPU cycles are
spent and each column should add to 100%. As a result, the numbers for
"system" and "" represent both idle and "work" cycles. If you
do that command in a totally idle system, you'll see that the columns
add to 100% and all the CPU cycles are spent in system and kernel, even
though there's no "real work" being done and "show cpu" shows 0% across
the board.
