01-17-2008 06:07 AM
I got this error this morning the event viewer stating that the service terminated unexpectedly. I have no idea on why this happened. Attached is the error log i got from the \\NMSRoot\lib\jre\bin directory and log directory. Any ideas on why that happened?
Solved! Go to Solution.
01-17-2008 06:02 PM
The crash may have caused the previous log to be overwritten. I checked on Sun's site, and a similar bug was reported with a preview of JVM 1.6 (which we are not using). That bug was considered rarely reproducible, so you may not experience this again.
01-17-2008 01:28 PM
This could be a memory problem. Please post the NMSROOT/MDC/tomcat/logs/stdout.log.
01-17-2008 01:33 PM
01-17-2008 01:46 PM
It appears Tomcat has been restarted. I need to see the previous log. It will be stdout.log.1.
01-17-2008 03:44 PM
That file should be in located in the same directory correct? All the other stdout.log files 1,2, and 3 have much older dates in the log and nothin current.
\\NMSroot\e$\CSCOpx\MDC\tomcat\logs
01-17-2008 04:24 PM
Yeah, same directory. If the messages pertaining to the crash are gone, I cannot say for certain what caused this.
01-17-2008 05:49 PM
That what it appears to be.....all the other stdlog files are date with 12/18/07.
Well if it happens again. I will post another discussion. Thanks.
01-17-2008 06:02 PM
