„Switch(config)#boot enable-break“ doesn't work for all switches
Jan 17th, 2008
Hi @ All,
the switch command “Switch(config)#boot enable-break” doesn't work. I've tested it on several Switches and it doesn't work for all models. The following list shows the result of my tests. The two first switches are working. The other three models don't work.
I am trying to recover the switches remote through access servers and have no opportunity to press the mode button. Therefore I'm trying to do it by software with this command. All tests are made directly via console, so that the access servers are not the problem.
The "show boot" command output indicates that the function was enabled on all tested switches,
>> sh boot
>> Enable Break: yes
My questions are:
1. Is there a possibility to solve this problem?
2. Is there any other solution to recover the switches without pressing the mode button?
Thanks in advance for your help.
Model Number: WS-C2940-8TT-S
BOOTLDR: (C2940-HBOOT-M) Version 12.1(13r)AY1, RELEASE SOFTWARE (fc1)
BOOTLDR_Compiled: Mon 30-Jun-03 15:16 by antonino
System Image: c2940-i6q4l2-mz.121-22.EA4/c2940-i6q4l2-mz.121-22.EA4.bin
System Image compiled Mon 12-Jul-04 08:18 by madison
Model Revision: E0
Motherboard: Revision: A0
Config Register: 0xF
Status: works
WS-C2960-24TT-L
BOOTLDR: (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
BOOTLDR_Compiled: -
System Image: c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin
System Image compiled: Fri 28-Jul-06 04:33 by yenanh
Model Revision: B0
Motherboard: Revision: C0
Status: works
WS-C2960-8TC-L
BOOTLDR: (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
BOOTLDR_Compiled: -
System Image: c2960-lanbasek9-mz.122-40.SE.bin
System Image compiled: Fri 24-Aug-07 01:55 by myl
Model Revision: A0
Status: doesn't work
WS-C2950T-24
BOOTLDR: (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
BOOTLDR_Compiled: Mon 22-Jul-02 17:18 by antonino
System Image: c2950-i6q4l2-mz.121-22.EA1.bin
System Image compiled: Mon 12-Jul-04 08:18 by madison
Model Revision: Q0
WS-C2950-24
BOOTLDR_Compiled: Mon 22-Jul-02 18:57 by antonino
System Image: c2950-i6k2l2q4-mz.121-22.EA10a.bin
System Image compiled: Tue 24-Jul-07 17:37 by antonino
Model Revision: B0
Motherboard: Revision: -
aghaznavi Wed, 01/23/2008 - 09:38
  • Silver, 250 points or more
Use boot manual global configuration command for enabling the manual boot process. For the switch to boot automatically, the manual boot feature must be disabled.
borisboettcher Thu, 01/24/2008 - 01:05
Hi, this works but doesn't solve my problem.
Cause i didn't want that the switch boots into ROMMON after a reload or a power cycle automatically. Instead i want to have only the opportunity to interrupt the reload by pressing the "Break" Sequence and force the switch to start in ROMMON.
On 2 of the 5 swicthes listed above this works fine but with the same configuration on other switch models it doesn't work:
Maybe you or someone has another idea?
