NSF/SSO on 6500 and Redundancy
Jan 17th, 2008
Can somebody confirm if you are now able to use both Gig Uplinks on Primary and Redundant Supervisors at the same time after upgrading to NSF? Also, if so are there any limitations as far as weather that port can be a trunk or a regular L3 port?
Jason
florence@upn.un... Thu, 01/17/2008 - 08:47
Hi Jason,
Yes it does , platform C6506, sup720-3B, Rel. s72033-advipservicesk9_wan-vz.122-33.SXH.bin.
I did nt saw limitation, I m using with trunks
on both GB ports on Primary Sup.
( Since August 2007 )
Francois
