UCM 6.0 Call Forward All issue
Jan 17th, 2008
When I deploy a phone to an end user and they push the CFwdALL button to forward to their cell phone, they get a "number cannot be dialed" error from the system. If I go into CM admin and manually enter the number they wish to forward their DN to it works. Then I undo the CFA in CM admin and the end user is subsequently able to use the CFwdALL from their phone. Is this normal, or a bug?
Overall Rating: 5 (1 ratings)
sadbulali Wed, 01/23/2008 - 09:23
  • Bronze, 100 points or more
Reset the following on both nodes. Cisco CTI Manager, Cisco TCD
Try logout and log back in.
Is the Forward All CSS set to None?
There is a CallManager Service Parameter under Clusterwide Parameters (Feature - Forward) called “CFA CSS Activation Policy”. Set this parameter to Activating Device/Line CSS, or change the CSS for Forward All on the DN you wish to allow call forwarding.
-John
