Cisco router 2500 and ADSL
Jan 17th, 2008
I want to configure Cisco router 2500 to used with ADSL line , how can I accomplish this while the I am using Router/modem in the front ,,can I use EIGRP configuration on the cisco router to advertise the internal real network.
ivillegas Wed, 01/23/2008 - 09:22
If you are suing a router you can definitely use EIGRP. If the number of networks are not large and if the network can be manually managed you can also go with Static routing.
