URL redirection on https with CSS
Answered Question
Jan 17th, 2008
We want to acheive the url redirection in such a way that, when user type https://192.168.10.171 it should get redirected to full url as https://192.168.10.171/uat/servlet/BrowserServlet
I tried searching the web, I could find some configurations for http to https redirection but that could not help me..
Below is the existing configuration of the CSS
*********************** SSL PROXY LIST ***********************
ssl-proxy-list UAT
ssl-server 1
ssl-server 1 rsakey BMKEYFILE
ssl-server 1 vip address 192.168.10.171
ssl-server 1 cipher rsa-export1024-with-rc4-56-sha 192.168.10.171 80 weight 10
ssl-server 1 cipher rsa-with-3des-ede-cbc-sha 192.168.10.171 80 weight 9
ssl-server 1 cipher rsa-with-rc4-128-sha 192.168.10.171 80 weight 8
ssl-server 1 cipher rsa-with-rc4-128-md5 192.168.10.171 80 weight 7
ssl-server 1 rsacert BMORIGCERTFILE
active
!************************** SERVICE **************************
service SSLMOD
type ssl-accel
slot 4
keepalive type none
add ssl-proxy-list UAT
active
service UAT-1
ip address 192.168.10.6
port 80
protocol tcp
redundant-index 1
keepalive type tcp
keepalive port 9080
active
service UAT-2
port 80
protocol tcp
redundant-index 2
ip address 192.168.10.86
keepalive type tcp
keepalive port 9080
active
service UAT-3
port 80
protocol tcp
redundant-index 3
keepalive port 9080
keepalive type tcp
active
!*************************** OWNER ***************************
owner BMAPP-CBS
content CBS-UAT
add service UAT-1
add service UAT-2
add service UAT-3
protocol tcp
port 80
url "/*"
redundant-index 101
advanced-balance sticky-srcip
active
content SSL-CBS-UAT
application ssl
protocol tcp
port 443
add service SSLMOD
active
!*************************** GROUP ***************************
group SourceNAT
add destination service UAT-1
add destination service UAT-2
add destination service UAT-3
redundant-index 201
active
Can someone give some inputs to acheive this...
Correct Answer by Diego Vargas about 9 years 1 month ago
You are already doing SSL termination for VIP 192.168.10.171.
There is no way to redirect https traffic since it is encrypted but you can can configure the redirect for a clear text rule that is going to be matched once the traffic is decrypted.
For instance, you can configure the content rule with url "/*" to send a redirect to
and remove the services from there
Then you create another rule more specific with the services added matching traffic going to URL /uat/servlet/BrowserServlet
Something like this:
content CBS-UAT
add service UAT-1
add service UAT-2
add service UAT-3
protocol tcp
port 80
url "/uat/servlet/BrowserServlet"
redundant-index 102
active
content CBS-UAT-redirect
protocol tcp
port 80
url "/*"
redundant-index 101
redirect "https://192.168.10.171/uat/servlet/BrowserServlet"
active
The traffic going to https://192.168.10.171 will be decrypted, then redirected to https://192.168.10.171/uat/servlet/BrowserServlet, decrypted again and finally balanced.
Hope it helps!!
Overall Rating: 4.5 (2 ratings)
Correct Answer
Diego Vargas Thu, 01/17/2008 - 07:31
content CBS-UAT
add service UAT-1
add service UAT-2
add service UAT-3
protocol tcp
port 80
redundant-index 102
active
protocol tcp
port 80
url "/*"
redundant-index 101
active
Hope it helps!!
