IP Phone unknown number display problem for incoming calls from PBX
sahmedshahcsd
We are having problem for incoming calls after integration of PBX system (Ericsson)with Cisco IP telephony integration has done successfully
But there is an unknown number message displayed on IP phones instead of actual phone extension numbers from PBX
Any ideas will be appreciated
Thanks in advance
Ahmed
paolo bevilacqua
To begin with, on the router do "debug isdn q931" and "term mon". This will tell you if the PBX is sending calling number and what else.
