IPsec VPN Problem
Jan 17th, 2008
We are currently experiencing a very peculiar problem with a IPsec VPN we have setup between 2 sites using Cisco 878 routers connected to 2MB SDSL circuits. The VPN comes up perfectly fine. We can ping across the 2 networks. However, nothing else works. When I try to access a server from one network to the other, I cannot telnet to port 25, 3389 or any other port. The access-list allows full IP. I have tried Drayteks routers to do the VPN and they work i.e. I can see all the relevant ports and they are open. The problem also occurs when using GRE to creat the VPN.
Therefore the Cisco routers are blocking the ports and I cannot see the reason why.
Please can someone help asap. Configs are attached.
ajagadee Thu, 01/17/2008 - 12:15
  • Cisco Employee,
Not sure why you have two acl entries for access-list 106 on Site 1 Router.
access-list 106 remark ### Crypto ACL ###
access-list 106 permit ip 10.0.1.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 106 permit ip 10.0.0.0 0.0.0.255 10.0.1.0 0.0.0.255
Can you reconfigure this to only one ACL, so it mirrors the ACL configured on the remote peer and do the testing again.
Let me know how it goes.
Arul
inderpalsogi Thu, 01/17/2008 - 14:05
Sorry, I have only the one access-list on each router. The config file was captured while doing some tests. Both routers have mirrored ACLs as shown below.
Site 1
Site 2
Therefore still no joy on this. Any other suggestions would be helpful.
Indy
dradhika Fri, 01/18/2008 - 06:06
  • Cisco Employee,
Hi Indy,
Can you try checking
sh crypto isakmp sa
If state column shows QM_IDLE then isakmp is established.
and
sh crypto ipsec sa
If you can line similar to the below lines then packets are getting encrypted.
#pkts encaps: 4, #pkts encrypt: 4, #pkts digest 4
#pkts decaps: 4, #pkts decrypt: 4, #pkts verify 4
Might be wrong in some other configuration.
Also can you check
1. set peer contains the dialer1 ip address
2. crypto key contains the dialer1 ip address
3. same key on both the routers
Radhika
inderpalsogi Fri, 01/18/2008 - 06:25
Hi Radhika
THanks for the response. I have checked the above. It does show as QM_IDLE in the state column. In addition when I do a sh crypto ipsec sa it shows
#pkts encaps: 1532, #pkts encrypt:1532, #pkts digest 1532
#pkts decaps: 1532, #pkts decrypt: 1532, #pkts verify 1532
I have also verified that the IP address in the set peer and crypto key contain the dialer1 ip address. The same key is also identical on both routers.
ajagadee Fri, 01/18/2008 - 08:05
  • Cisco Employee,
Based upon the outputs, the tunnel is up and encrypting/decrypting traffic. Did you capture these outputs from the local router or the remote one.
1. Can you paste the current running configuration from both the routers.
2. Show crypto isa sa and Show crypto ipsec sa from both the routers
3. Also, where are you sourcing the packets from and what is the destination address.
Arul
Christian Osburg Fri, 01/18/2008 - 11:47
Hello Indy,
i've got a similar problem last year.
The answer of the problem was the ip tcp adjust-mss config on both sites. I think i changed the tcp adjust-mss on both sites to 1500.
Maybe you can change the tcp adjust-mss in the dialer and vlan interface on both sites to 1500 (in your config it's 1460).
When you ping over a longer time (maybe 5 minutes) across the networks, please tell me if there is anything fine or if you got errors ("connection lost" or so).
Sorry my english isn't very good yet ;)
Hope i can help you.
Greetings
Christian
inderpalsogi Sat, 01/19/2008 - 14:15
Hi Christian
There is no way you can put ip tcp adjust-mss 1500 on the dialer or vlan interface. The cisco command only allows up to 1492. I had tried to change the values both up and down. However, problem still exists.
I can ping perfectly fine across the two networks. But nothing else is accessible on any port i.e. smtp, rdp, http, https
anitachoi3 Sun, 01/20/2008 - 06:29
try following to see the problem is solved or not
!site A
interface Dialer1
no ip access-group 111 in
! site B
interface Dialer1
use the extend ping to test the connectivity.
rgds
inderpalsogi Sun, 01/20/2008 - 08:10
I have removed the ip access-group 111 in from both routers. This came to no avail. I have used almost identical configs at other sites. I only seem to have a problem with the VPN between these 2 sites using the Cisco routers.
anitachoi3 Sun, 01/20/2008 - 09:02
remove the acl from the interface and add following
! site A
no ip nat inside source list 105 interface Dialer1 overload
ip nat inside source route-map nonat interface Dialer1 overload
access-list 100 deny ip 10.0.0.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
route-map nonat permit 10
match ip address 100
! site B
access-list 100 deny ip 10.0.1.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 100 permit ip 10.0.1.0 0.0.0.255 any
ajagadee Sun, 01/20/2008 - 21:04
  • Cisco Employee,
Based upon the outputs, the tunnel is up and encrypting/decrypting traffic. Did you capture these outputs from the local router or the remote one. If you dont mind, can you provide the below information.
3. Also, what is the source and destination IP Addresses of your testing.
4. Can you also do a clear ip nat translations * and do the testing again.
Arul
inderpalsogi Mon, 01/21/2008 - 05:27
I will get these logs to you at some stage tomorrow.
Indy
inderpalsogi Tue, 01/22/2008 - 10:51
Hi Arul
All the configuration files you requested have been attached.
I am still pulling my hair out on this. I do not know where I am going wrong.
I can only attach 3 documents per reply, so I will attach all on 3 replies.
Indy
anitachoi3 Thu, 01/24/2008 - 07:09
It seems that the vpn is up and running. you can access site A from site B.
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 10.0.1.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/32/36 ms
any problem you have?
rgds
inderpalsogi Thu, 01/24/2008 - 07:21
the problem is i have a server at 10.0.1.1 which has ports 25,3389,443,110 open on it. However, from the other site, I cannot telnet to these TCP ports from a command prompt. This tells me that the cisco routers are blocking these ports. I have implemented this vpn using draytek routers and do not have this problem. THe cisco routers seem to be blocking the ports on the VPN. Being able to just ping between the sites is no good for me.
anitachoi3 Thu, 01/24/2008 - 09:05
try following:
! site a and site b
! step 1
no ip nat inside source static tcp 10.0.1.1 80 interface Dialer1 80
no ip nat inside source static tcp 10.0.1.1 3389 interface Dialer1 3389
no ip nat inside source static tcp 10.0.1.1 25 interface Dialer1 25
no ip nat inside source static tcp 10.0.1.1 110 interface Dialer1 110
no ip nat inside source static tcp 10.0.1.1 443 interface Dialer1 443
no ip nat inside source static tcp 10.0.1.1 143 interface Dialer1 143
no ip nat inside source static tcp 10.0.1.1 3000 interface Dialer1 3000
! step 2
on 10.0.0.x PC, ping 10.0.1.1
if it works
! step 3
on 10.0.0.x PC, telnet 10.0.1.1
rgds
inderpalsogi Thu, 01/24/2008 - 09:11
If i remove these no ip nat statements, I will not be able to access the server from the Public internet via the Internet. Is there any other way?
Indy
ajagadee Thu, 01/24/2008 - 09:40
  • Cisco Employee,
Thanks for all the show outputs :-))
At this point of time, I think the best course of troubleshooting is define an ACL and do a debug IP Packet on it and see where the packets are getting dropped. Also, running debugs on production box may have a lot of impact on the routers, so I would recommend that you test this during non-production hours.
For example
access-list 150 permit ip host 10.0.0.1 host 10.0.1.1
access-list 150 permit ip host 10.0.1.1 host 10.0.0.1
Router#deb ip packet detail 150
IP packet debugging is on (detailed) for access list 150
Arul
anitachoi3 Fri, 01/25/2008 - 10:34
can you telnet to 10.0.1.1 from 10.0.0.x segment?
rgds
inderpalsogi Fri, 01/25/2008 - 11:03
Unfortunately I cannot. But I have not tried your advice about removing the static NAT commands yet.
Indy
anitachoi3 Thu, 01/24/2008 - 09:12
if you enable the VPN, pls do not enable the static nat. It will cause some issue regarding the services via internal network but outsider (Internat) can access those services without any problem.
rgds
inderpalsogi Thu, 01/24/2008 - 09:14
How will the outsider be able to access those services if there are no nat statements defined using the dialer interface.
anitachoi3 Fri, 01/25/2008 - 11:45
can you telnet to 10.0.1.1 from 10.0.0.0 segment?
rdgs
anitachoi3 Sat, 01/26/2008 - 10:17
can you telnet 10.0.1.1 form 10.0.0.0 segment? if yes, you may move on next step to enable outsider to access internal.
rgds
