Vlan management access - Telnet
Jan 17th, 2008
I connected a 3750 to a 2960G via a 2 port etherchannel. both running ios 12.2(25)SEE. i cannot ping the vlan1 ip (the ip i set the switch up with at the beginning) nor telnet to it. I can console to it, although this is a work around its kind a pain when it in a rack, and traffic goes thru it (i.e. all the devices connected to it can talk to and from the rest of the network. any ideas where i might look to resolve being able to telnet?
glen.grant Thu, 01/17/2008 - 13:22
Is vlan 1 the only thing the etherchannel is carrying? I would post the config. Very ip address of the 2960 and the 3750 are in the same address range , make sure default gateway is correct on the 2960 .
