open port range
Jan 17th, 2008
I have an 1841 with IOS 12.4 connected to an isp with a single subnet - I am trying to create and access list for IP phone access to a single internal IP on ports:
5566 tcp
5567 udp
6004-7039 udp
I can nat the first two with static entries but I cannot seem to get the port range to work?
Thank you in advance for any help
ebreniz Wed, 01/23/2008 - 09:09
  • Silver, 250 points or more
In order to open certain range of TCP or UDP ports on PIX, use the service object group and define it in an ACL or conduit. Refer to this configuration example:
PIX (config)#object-group service tcp
PIX(config-service)#port-object range <1-65535>
PIX (config)#object-group service udp
Bind the object-groups with access-lists:
PIX (config)#access-list permit tcp any any object-group
PIX (config)#access-list permit udp any any object-group
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800d641d.shtml#serv
