Dynamic search application
Jan 17th, 2008
I need an application to enter a letter that and the application return the results that are consistent with that letter and so for each letter that you insert,
Mike-1985 Fri, 01/18/2008 - 00:18
Some more information would be useful.
You need a CiscoIPPhoneInput xml object to let the user enter one or more letters. This input form gets send you a specified server. This server makes the search in whatever database or anything you want and wraps the result in a Cisco IPPhone XML object.
exg801130 Fri, 01/18/2008 - 08:05
Thanks for you answer but i need in the same screen the CiscoIPPhoneInput and the results, at the time that i write in this time the result are been display by the phone
