Jagdeep Gambhir Fri, 01/18/2008 - 05:57
  • Red, 2250 points or more
ACS is not supported on system running dual NIC's . It will create lots of problem during
replication process and during authentication also
~JG
Do rate if helps
cisco24x7 Fri, 01/18/2008 - 12:07
  • Silver, 250 points or more
Running ACS on system with multiple NICs is
not supported by Cisco TAC but it does work.
You just need to make sure you have proper
route(s) on the ACS server back to the
request client. It does work and I used it
to prepare it for the CCIE Security lab.
CCIE security
