Windows 2003 DFM 3.0.1 stays 10% pending
Jan 18th, 2008
I have removed Microsoft .NET FRAMEWORK 2.0 service pack 1
I have deleted my devices now all stay in pending state.
IP Address = 139.88.204.129
DNS Name = ap105-107-1.testlab.com
Device Status = Pending
Device Type = N/A
Aliases = N/A
Containments = N/A
DFM Processing = N/A
Time Last Discovered = N/A
Import Time Stamp = 17-Jan-2008 17:50:20
*** Data Collector Status Information ***
Discovery Progress = 10% completed
Error Code =N/A
Error Message = N/A
There appears to be some type of service process problem.
DFMlogserver.log
18/Jan/2008 08:30:53:271 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:30:55:271 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:30:57:271 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:30:59:287 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:01:287 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:03:287 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:05:287 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:07:287 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:09:302 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:10:943 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
18/Jan/2008 08:31:11:302 ERROR ? ? - URN_NOT_FOUND : urn "VPTA" : Not found !!
tstanik Thu, 01/24/2008 - 10:52
Stuck at 10% usually indicates a problem with DfmServer or DfmBroker. Make sure both of these daemons are running. You can also try to disable the trap receiver in DFM by going to DFM > Configuration > Other Configurations > SNMP Trap Receiving, and set the port to either 0, or some other free UDP port (e.g. 9000).
davidfranek Thu, 01/24/2008 - 15:12
C:\Documents and Settings\gnoc>pdshow DfmServer
Process= DfmServer
State = Program started - No mgt msgs received
Pid = 14100
RC = 0
Signo = 0
Start = 1/24/2008 2:08:52 PM
Stop = Not applicable
Core = Not applicable
Info = Server started by admin request
C:\Documents and Settings\gnoc>pdshow DfmBroker
Process= DfmBroker
State = Running normally
Pid = 5036
RC = 0
Signo = 0
Start = 1/24/2008 8:34:09 AM
Info = DFM broker Running
Made changes to SNMP settingsIP Address = 139.88.125.26
DNS Name = ap-16.grc.nasa.gov
Device Status = Learning
Device Type = N/A
Aliases = N/A
Containments = N/A
Import Time Stamp = 24-Jan-2008 09:43:59
Error Code = N/A
Error Message = N/A
All devices stay learning
tarapulka Fri, 02/01/2008 - 07:47
Did you restart the daemons after uninstallation of .Net 2.0?
