Zin.Karzazi Fri, 01/18/2008 - 06:30
  • Silver, 250 points or more
On your CCM webadmin page:
Got to aplication->Cisco Callmanager Serviceability->Tools->Serviceability Report Archive
OR
Use RTMT. Open RTMT->Performance->YOur CCM-> Cisco H323 (or MGCP, depends on what you are using)-> Double Click Call Active-> select Gateways you have-> you will now have a graph showing the number of all B Channels used, right click on it select-> Alert / Treshold-> Enable Alert (Severity: Warning-> Click Next: on "trigger alert when the following condition meet" select a Value ie Over 25 (which means when 25 B channels=Calls are simultanueously used you will get an email alert of it). Do this for all Gateways and all Callmanager processing Calls.
Karzazi
hannyong Sun, 01/27/2008 - 23:43
if the gateway has got 5 PRI lines, the graph will be representing 150 channels(assume E1). Anyway possible to monitor per port or per E1?
