How do I reset the values displayed by the SHOW BOOT command
Answered Question
Overall Rating: 4.5 (3 ratings)
Danilo Dy Fri, 01/18/2008 - 06:31
  • Blue, 1500 points or more
Is this a router or a switch and what model?
Dandy
Dear Dandy,
This is a switch model Catalyst 3500 series XL model WS-C3534-XL-EN.
I have now resolved one issue setting "Config file:" to "flash:config.text" by entering "configure terminal" mode followed by the "BOOT config-file flash:config.text" command.
I still wish to set the “BOOT path-list:” to a null value.
In addition I wish to set the “Enable Break:” from a value of “1” to a value of “no”.
Danilo Dy Fri, 01/18/2008 - 07:45
To set enable break from 1 (or yes) to 0 or (no);
switch# config t
switch(config-t)#no boot enable-break
To set boot path-list to null
switch# config t
switch(config-t)#no boot system
Dandy
Correct Answer
Danilo Dy Fri, 01/18/2008 - 08:08
Did you use "no boot system"? I edit the early post from "no boot boothlpr" to "no boot system"
Dandy
