Normal traffic into DSCP EF
Jan 18th, 2008
i know dscp EF is for voice, can i config some traffic which behavior like normal data traffic(characteristic not like voice),but it is very important, something like air traffic monitor data.
a flight send data to central computer. The data is dynamic,real time. it's high priority,can't allow losing. this data is base TCP/udp. not like voice,it is not sensitive for delay and jitter, but can't allow loosing and should be transfered to central computer in time.
can i put this data into LLQ ,dscp EF,mpls EXP 5. data is transfered in mpls vpn network.
is there any problem.
Thank you!
Tom
htarra Thu, 01/24/2008 - 10:58
  • Bronze, 100 points or more
QoS should be used to create separation between traffic classes and used as a tool to get better awareness and control of your traffic flows. yes you can this data into LLQ ,dscp EF,mpls and this can be work fine.
