Test Lab
Jan 18th, 2008
Hi gurus
I would like to setup a test site-to-site lab, I have two 871 routers and two computers for this purpose but what do I need in between to setup this test lab to work as they where in different place(state) and all. as you can tell I am new to network but like to learn, so go easy on me
Thanks a bunch
plumbis000 Fri, 01/18/2008 - 06:54
You just need three subnets.
[SubnetA]---[871]----[871]----[SubnetB]
naguaramipana01 Fri, 01/18/2008 - 07:01
P.
Thanks but can you be more specific
what do I use in between a switch to connect the two routers
I know there is a wan and lan on each router so how do I go on getting everything together to connect both computer.
Thanks for battling with me here
plumbis000 Fri, 01/18/2008 - 08:35
I'm not sure what you are asking exactly. You can connect the routers together via any interfaces available (including ethernet WAN ports). You just need to make sure your addressing is correct and then you can enable a routing protocol, like RIP, to advertise the subnets. For example...
RouterA
int f0
no shut
int f4
ip add 10.0.0.1 255.255.255.0
no shut
router rip
network 10.0.0.0
network 192.168.1.1
RouterB
int f0
ip address 192.168.2.1 255.255.255.0
no shut
int f4
ip address 10.0.0.2 255.255.255.0
no shut
router rip
network 192.168.2.0
network 10.0.0.0
You don't necessarily need anything connected to the f0 ports, and just connect the two routers together via the f4 ports. If you want to use a switch in there, you can either place it between the two devices as a passive layer2 item or on either router off the f0 port.
Hope that helps clear things up a little more.
Ibbywannit Fri, 01/18/2008 - 09:34
If you really are new to networking and wnat to go back to basics, then first you'll probably need to serial interfaces on your routers.
You will also need a DCE/DTE cable to emulate the lab environment - the DCE will be a service provider (you'll need to set the clock rate and also the "no shutdown" command to enable the interface) and the DTE will be the customer end.
Then add any of the ip addresses to the interfaces like explained above.
If you want to exchange packets across the link (technically this is now a WAN link - because it's using the serial interfaces), you can use a static link - or you can choose one of a number of dynamic routing protocols, etc.
Hope that's a help.
