PEAP authentication
Jan 18th, 2008
I've impelemented the PEAP authentication successfully.
when trying to connect to the network,the station prompt for the username and password just for the first connection,and then it stores that username/password in the registry base.
can I do somthing to make it prompts in each connection?
ismail884 Mon, 01/21/2008 - 07:39
I've delete the registre entry for EAPoL,But each time connected it re-enable it.
is there another solution that permit to prompt for Login/password for each connection.?
valstan Mon, 01/21/2008 - 14:08
Do you have the "Enable Fast Reconnect" disabled in the Global Authentication Setup?
cisco24x7 Tue, 01/22/2008 - 06:55
I am having the same exact issue as ismail884.
However, I am using steelbelted/juniper
radius for PEAP authentication instead of Cisco
ACS. I also have "enable FAST-PEAP" disabled
in steelbelted radius but somehow the credential
still cache on the windows client.
