Telnet access and syslog messages
Jan 18th, 2008
in this forum I found that to log telnet access to routers (Successful/Unsuccessful - Authorized/Unauthorized) a possible configuration is:
access-list 10 permit 10.1.1.1
access-list 10 permit 10.51.21.34
access-list 10 permit 10.51.8.32
I find on cisco.com these syslog events related to telnet:
%TN-2-BADLOGIN : Bad login string pointer [hex]
%TN-3-BADSTATE : Illegal state [dec]
%TN-3-READLINE : Unknown return code [dec] from telnet_readline()
(http://www.cisco.com/en/US/docs/ios/12_3/sem2/system/messages/emgtdm.html#wp139576)
"%TN-2-BADLOGIN : Bad login string pointer [hex]" is related to unauthorized telnet access to the router?
Can you suggest me some syslog messages generated when someone tries to access a router?
Thanks a lot
ivillegas Thu, 01/24/2008 - 11:14
  • Silver, 250 points or more
I have experienced "% telnet connections not permitted from this terminal " messages on the console. Issuing the command "transport output telnet ssh " under line vty 04 resolves this issues.
cisco24x7 Thu, 01/24/2008 - 12:01
Try this:
login block-for 1 attempts 3 within 1
login delay 1
login on-failure log
Here is a message of someone login unsuccessfully to a router:
Jan 24 17:59:16 10.109.114.101 13632: Jan 24 19:59:15: %SEC_LOGIN-4-LOGIN_FAILED: Login failed [user: dkdkdk] [Source: 192.168.1.1] [localport: 23] [Reason: Login Authentication Failed - BadUser] at 19:59:15 UTC Thu Jan 24 2008
Easy right?
CCIE Security
fisko Wed, 04/21/2010 - 00:08
What about OLD IOS this is extended login feature in 12.4(3)?
