VoiceGateway and SIP line Problem.
Jan 18th, 2008
Hi Friends,
i've got a big problem, i have 5 SIP line with username and password, one router 2821, and a serial port that is configured with 2 MCR one for Internet and the other for VoIP. How can I configure all 5 user and password? i have tried in this way:
sip-ua
credentials username 390392910838 password 0757716B6A2B282741 realm wind.it
credentials username 390392910837 password 096E17214E20273D22 realm wind.it
credentials username 390392910839 password 135526412E5C2D0E0D realm wind.it
credentials username 390392910840 password 00533C34200B5B365C realm wind.it
credentials username 390392910841 password 132E31335A58211A79 realm wind.it
but only one of this account is registering. How can i configure multiple account? thanks.
matteo.margheritini Sun, 01/20/2008 - 23:58
So I can't use all the line, and i must use only one telephone number? there isn't a workaround for this problem?
Paolo Bevilacqua Tue, 01/29/2008 - 14:49
Hi Matteo,
I ran across a simple technique to register multiple numbers for SIP.
Under a DP pots, configure "authentication username password ".
Realm is also supported but optional.
Configure destiona-pattern of the number you want to register, and preference 10 to avoid sending the number out via pots port.
